MHW, I concatenated my initial August 26 comments as an answer to your original question. Cheers.
@MHW, you're correct on the use of ZoneHVAC:IdealLoadsAirSystem to address your needs. Note: I updated your Engineering Reference link to 24.1 (updated since from 8.0). I suggest you check out as well the 24.1 IO Reference:
  • how required energy is metered/reported
  • required fields
  • actual outputs
  • better documented in general
You may also find it insightful to consult related issues, past or current. And consulting any example file(s) that come with EnergyPlus is always useful.
(see above for follow-up Q/A)
  • required fields
  • actual outputs
