I think you are referring to a ceiling fan. You can watch this brief tutorial to learn more about the modeling process: https://www.youtube.com/watch?v=H9qjW2NYcCE&ab_channel=BrendonLevitt
The fan you were looking at is part of the mechanical systems (e.g., fans in a 4-pipe system). For ceiling fans, you need to define them under the Electric Equipment. But I don't think you see a big energy-saving unless the ceiling fan increases the cooling setpoints significantly. If you are looking for energy conservation measures, natural ventilation would show a higher impact.
