There are three possible ways to add a window:
- Open the openstudio space and draw a closed polygon inside a wall
- Draw a closed polygon close to the wall but without opening the space and the use the tool "Project Loose Geometry".
- Use the OpenStudio User Script "Set Window to Wall Ratio".
You can add a frame with the OpenStudio User Script "Set Windows Property Frame and Divider".
