This is not easy to do from the detailed mode, and requires you to manually edit the .inp file in a text editor.
Create a copy of the .inp file and then adjust the vertices of the geometry as required.
There is a lot that can go wrong with this process so take your time and work cautiously.
This is probably the single biggest disadvantage to using eQUEST.
Good luck.
