OpenStudio is fairly picky (probably overly picky) about the types of schedules that are allowed for different objects. I assume you are talking about the Refrigerated Case Restocking Schedule of the OS:Refrigeration:Case object. The type of schedule allowed for this field is specified here as 'LinearPowerDensity'. Currently, there is no good way to change the schedule type limits on a schedule after it is created. You can open the OSM in a text file, find the schedule type limits associated with your schedule and make sure its Unit Type is set to LinearPowerDensity.
