As far as I know, the IdealLoadsAirSystem didn't build a full HVAC system and assumes 100% efficiency. It won't generate heating and cooling electricity consumption, instead it would be under District Cooling and District Heating columns in your html report which accounts for load-only calculation. Hope it helps. And an idf would help to address your problem too.
As far as I know, the IdealLoadsAirSystem didn't build a full HVAC system and assumes 100% efficiency. It won't generate heating and cooling electricity consumption, consumption in the report, instead it would be under District Cooling and District Heating columns in your html report which accounts for load-only calculation. Hope it helps. And an idf would help to address your problem too.
As far as I know, the IdealLoadsAirSystem didn't build a full HVAC system and assumes a 100% efficiency. efficient system. It won't generate heating and cooling electricity consumption in the report, instead it would be under District Cooling and District Heating columns in your html report which accounts for load-only calculation. Hope it helps. And an idf would help to address your problem too.too.
