TL;DR: use the IDF::idfstr() method to get the string, then output that to a file once you're done.
I doubt you are going to be critically bound with I/O here, so the quickest workaround is to save to a file then read it with python. Otherwise, the code use to save is pretty simple and located modeleditor.py#L907:L953. You can easily modify that to only keep the string via IDF::idfstr() method, do stuff on it, and still save ultimately in the same format that eppy does.
Let's load some dummy data, and two system modules we will optionally need to encode:
import platform
import os
from eppy import modeleditor
from eppy.modeleditor import IDF
# Set Idd
iddfile = r'/usr/local/EnergyPlus-9-0-1/Energy+.idd'
IDF.setiddname(iddfile)
# Load example file
p = r'/usr/local/EnergyPlus-9-0-1/ExampleFiles/1ZoneUncontrolled.idf'
idf1 = IDF(p)
Now here's the thing:
# Get the idf as a string
s = idf1.idfstr()
# **Do stuff here**
# Optional Encoding like eppy would do by default (lineendings = 'default', encoding='latin-1')
encoding = 'latin-1'
system = platform.system()
s = '!- {} Line endings \n'.format(system) + s
slines = s.splitlines()
# Make it a single string
s = os.linesep.join(slines)
s = s.encode(encoding)
# s is your idf enconded string ready to write
with open('myfile.idf', 'wb') as idf_out:
    idf_out.write(s)
I doubt you are going to be critically bound with I/O here, so the quickest workaround is to save to a file then read it with python. Otherwise, the code use to save is pretty simple and located modeleditor.py#L907:L953. You can easily modify that to only keep the string via IDF::idfstr() method, do stuff on it, and still save ultimately in the same format that eppy does.string.
import platform
import os
# Set Idd
# Load example file
idf1 = IDF(p)
s = idf1.idfstr()
# **Do stuff here**
string
    idf_out.write(s)
# **Or do stuff here**
