There should be a sub-folder within the DesignBuilder schedules library called "ASHRAE 90.1-2007." Most of these profiles come from the ASHRAE 90.1-2007 User's Manual, which are generally considered acceptable for load profile assumptions in the absence of more detailed programmatic scheduling. I don't know where the non-ASHRAE schedules come from, but if you're concerned about their validity then I'd stick with the ones under the ASHRAE sub-folder.
