Ideal Load Air System is a concept totally equivalent to purchased air. Check the input output reference manual. You can use the HVACTemplate objects for convenience:
Or the ZoneHVAC:IdealLoadsAirSystem directly.
Ideal Load Air System is a concept totally equivalent to purchased air. Check the input output reference manual. You can use the HVACTemplate objects for convenience:use:
Or the ZoneHVAC:IdealLoadsAirSystem directly.HVACTemplate:Thermostat
Ideal Load Air System is a concept totally equivalent to purchased air. Check the input output reference manual. You can use:
HVACTemplate:Zone:IdealLoadsAirSystem
HVACTemplate:Zone:IdealLoadsAirSystem HVACTemplate:Thermostat
