The best solution for you today is the OpenStudio analysis spreadsheet. It uses Excel as an interface to define a problem an parameter space.
If you can wait a until the end of March our next release of PAT 2 will be out which adds the ability sweep across climate zones using the Prototype or other measures. It is also supports the algorithmic analysis.
If you only wanted to sweep across building types and vintages then PAT 1 would work. It has issues sweeping across climate zones.
