It depends of the programation on Model Options. If you designate Detailed HVAC and Option 2-Detailed HVAC Data in Detailed HVAC Activity data, the (Des)Humidification setpoint used are the setpoints in HVAC Zone. Otherwise, if you designate Option 1-Simple HVAC Data in Detailed HVAC Activity data, the (Des)Humidification setpoint used are the setpoints in Activity Data. You have to model (Des)Humidification process in AHUs modeled.
I recommend you seeing this text:
https://www.designbuilder.co.uk/helpv4.7/#HumidityControl.htm
