If it is the same as DOE2.2, you should see a file that looks like CECDDT<>.bin
As far as parsing goes, you may have to look into the source code to see if they do any data compression or encryption before writing to the .bin file (perhaps similar to the strategy used int he weather .bin files). I could be wrong, but the binary output option was probably never meant to be used by end users.
You may want to try the HOURLY-REPORT-SAVE = FORMATTED option. Again, if this were DOE2.2, you'll see a file like CEC2<>.DAT which is a plain text fixed-format file that can easily be opened in excel. It should have the same data as the binary file, but it will be larger and readable.
