If the table was skipped for some reason you should have seen a message something like this. A ruby error will break the entire section but some tables may gracefully fail if a sql query doesn't turn out what is expected.
"One or more tables in #{display_name} section returned false and was skipped."
For 1.13.1 I've made an update that will prevent the standard report from running if the tabular EnergyPlus results are not in SI units. Here is an issue that shows what it will look like. The reason for this is that the results you will be wrong where unit conversion is required.
