I don't know of a .ddy dataset and I haven't looked for it (I'm assuming you've searched online prior to posting).
But it'll be very easy to create... The link you gave has .imf file. It's basically a collection of the SizingPeriod:DesignDay objects encompassed in if statements.
##ifdef KEY
SizingPeriod:DesignDay (1st for the location)
SizingPeriod:DesignDay (12th for the location)
##endif
##ifdef ANOTHER_KEY
##endif
The key can be found in the csv file.
So if you need a couple locations, do it manually.
Otherwise, you can write something that'll parse it out and save as individual files in 10 or less lines of code.
