It looks like in your case, you dragged a Hot Water Coil onto the Plant Loop, but this coil is not inside of a PTAC or attached to an Air Loop. I would try deleting the coil then following these steps to add a PTAC:
On the Thermal Zones Tab, drag a PTAC from the library into each zone
Click on each PTAC
- Click on the Chain Link icon in the upper right
- Click the check box to connect the PTAC to the Hot Water Loop (which you've already created)
