Thank you very much. I feared so that it was a mistake to make just one space, but it is good to know that this was the mistake and I can start over without making the same mistake.
No need to spend more time with this model if that is the case. I already have a good enough guide for remodeling it and much detail is not needed.
I will try again with more spaces this time, at least a core and a perimeter as you suggested, probably more since just one for the perimeter will probably not be enough as it is indeed a complex building.
Certainbly I need to educate myself more about the programms, but I have no physical person to turn to, so the mistakes escalate. One less to go now though. Another one I did was to forget choosing the surface before drawing the sub-surface.
How did you make the horizontal cut? It is a useful tool that I have not managed to find yet. EDIT: Just found it by googling "sketchup section", with the use of the plane section tool. Nevermind that.
A million thanks again, I will start over and if any issue presents itself I will know who to ask for it.
How did you make the horizontal cut? It is a useful tool that I have not managed to find yet. EDIT: Just found it by googling "sketchup section", with the use of the plane section tool. Nevermind that.yet.
