Currently, OpenStudio can't read all the IDF objects. For example, it can read the geometry from IDF file and it can't read most of the HVAC systems. So far as I know, all the energy modeling tools with good user interface can only handle part of the IDF objects.
So the messages you received is informative. They are not "Errors". You can follow the information to export the untranslated objects.
I checked two BuildingSurface:Detailed for the same wall. They have same coordinates. So the two BuildingSurface:Detailed objects show in the same zone, while the nearby zone shows "missing wall".
     ! Block 2, Hol, Partition - 3.913 m2 (Block 2, Yasam10), Surface Area: 3.9132
     BuildingSurface:Detailed,                      !- Surface
            Block2:Hol_Partition_41_0_0,                !- Surface name
            Wall, Balatcik_BolmeDuvar_UnitelerArasi,    !- Class and Construction Name
            Block2:Hol,                                 !- Zone Name
            Surface, Block2:Yasam10_Partition_6_0_10049,   !- Outside Face Environment
            NoSun,                                      !- Sun Exposure
            NoWind,                                     !- Wind Exposure
            0,                                          !- View Factor to Ground
            4,                                          !- Number vertices
             2.0222122255,-4.9760001718, 19.09753871,   !- Vertex 1
             2.0213437487,-3.3280264607, 19.09753871,   !- Vertex 2
             2.0213437487,-3.3280264607, 21.47207749,   !- Vertex 3
             2.0222122255,-4.9760001718, 21.47207749;   !- Vertex 4
     ! Block 2, Hol, Partition - 3.913 m2 (Block 2, Yasam10), Surface Area: 3.9132 <Other side>
     BuildingSurface:Detailed,                      !- Surface reverse definition
            Block2:Yasam10_Partition_6_0_10049,         !- Surface name
            Wall, Balatcik_BolmeDuvar_UnitelerArasi_Rev,!- Class and Construction Name
            Block2:Yasam10,                             !- Zone Name
            Surface, Block2:Hol_Partition_41_0_0,       !- Outside Face Environment
             2.0213437487,-3.3280264607, 19.09753871,   !- Vertex 1
             2.0222122255,-4.9760001718, 19.09753871,   !- Vertex 2
             2.0222122255,-4.9760001718, 21.47207749,   !- Vertex 3
             2.0213437487,-3.3280264607, 21.47207749;   !- Vertex 4
