As could be drawn from the above discussion, the solution to this issue is not related to EnergyPlus. It is related to IDF Editor.
@JasonGlazer and @Denis Bourgeois raise some good points for the same and this answer stems from their guidance.
The solution to the above problem is as follows:
- Open the IDD file of EnergyPlus in Notepad or any suitable editor.
- Find the "Spacelist" object. This shall have these (click the link) parameters, as provided by @Denis Bourgeois in above comment. It will look like this in Notepad:
A1 , \field Name \note Name of the SpaceList. \note This name must be unique across Zone, Space, ZoneList, and SpaceList names. \required-field \type alpha \reference SpaceListNames \reference SpaceAndSpaceListNames \reference ZoneAndZoneListAndSpaceAndSpaceListNames A2 , \field Space 1 Name \begin-extensible \required-field \type object-list \object-list SpaceNames ... and so on till A50; \field Space 49 Name \type object-list \object-list SpaceNames
- Open the IDF file in Notepad or any suitable editor.
- Find the "Spacelist" object. Investigate the maximum number of "Space Names" in IDF. In my case this was "87" as indicated by the following (copying a portion of a Spacelist object from my IDF):
... T5_Residential_L14, !- Space Name 80 T5_Residential_L18, !- Space Name 81 T5_Residential_L8, !- Space Name 82 T5_Residential_L32, !- Space Name 83 T5_Residential_L4, !- Space Name 84 T5_Residential_L29, !- Space Name 85 T5_Residential_L5, !- Space Name 86 T5_Residential_L20; !- Space Name 87
- Go back to IDD file in Notepad.
- Remove the semicolon (;) after "A50" and replace it with comma (,)
- After:
A50, \field Space 49 Name \type object-list \object-list SpaceNames
... add the following:
A51, \field Space 50 Name \type object-list \object-list SpaceNames
- Keep repeating this (adding/incrementing fields) till you have:
A88; \field Space 87 Name \type object-list \object-list SpaceNames
- Save and close the IDD file.
- Open IDF in IDF Editor, it shall work fine.
Cheers!
If you find this answer helpful, please upvote. Thank you.
editor.error. - Find the "Spacelist" object. This shall have these (click the link) parameters, as provided by @Denis Bourgeois in above comment. It will look like this in Notepad:
editor.error. - Find the "Spacelist" object. Investigate the maximum number of "Space Names" in IDF. In my case this was "87" as indicated by the following (copying a portion of a Spacelist object from my IDF):
- After:
Cheers!
- Open the IDD file of EnergyPlus in Notepad or any suitable error.
- Open the IDF file in Notepad or any suitable error.
- After:
Cheers!
- After:
(adding/incrementing fields)till you have:
Cheers!
