The cooling coil outlet air set point temperature is 17.65 C and the coil entering water temperature is 19.46 C so it is not possible to reduce the air temperature below 19.46 C. The problem here is that the chilled water is not cold enough. Either the plant leaving water temperature set point is too high or the plant is not able to reduce the water temperature to the set point.
