The problem is that you cannot have a surface with a hole in it (as your roof and floor do). If you simply make a connection from the hole to the outside of the surface, it will make a single surface with one shared edge:
This should apply the correct boundary conditions after matching. For example:
The problem is that you cannot have a surface with a hole in it (as your roof and floor do). it. If you simply make a connection from the hole to the outside of the surface, it will make a single surface with one shared edge:
