OutputControlTableStyle isn't likely mapped to the OpenStudio Application.
"Could this be done by writing my own OpenStudio measure?" Indeed, that would be the safest route. The easiest in the short term is to hack your .osm files, by copying/pasting the following:
OS:OutputControl:Table:Style,
{9206745e-ee26-45d1-8c25-e06c38b989e7}, !- Handle
HTML, !- Column Separator
JtoKWH; !- Unit Conversion
... make sure the Handle is unique.
I generated this using IRB (probably can do the same with the Python Interpreter):
require 'openstudio'
model = OpenStudio::Model::Model.new
puts model.getOutputControlTableStyle
None; !- Unit Conversion
... and changed None to JtoKWH after copying/pasting.
A very simple script could accomplish the same if you had hundreds of files to modify. Hope this helps.
