With current EnergyPlus v8.3.0 capabilities, the ChillerHeater with an unused chilled water loop is the best available option. You can set the Condenser Type to AirCooled and drop the condenser loop.
With current EnergyPlus v8.3.0 capabilities, the ChillerHeater with an unused chilled water loop is it the best available option. You can set the Condenser Type to AirCooled and drop the condenser loop.
