The EnergyPlus engine has hundreds of outputs that can be requested and they depend on the model you have defined.
You can view all available output variables either in the .rdd file or through the EMS scripting add output interface. The step-by-step instructions are described in this knowledgebase article. https://support.designbuilder.co.uk/support/solutions/articles/103000181523-requesting-additional-outputs-for-your-simulation
Depending on the model you use, you may have access to the following outputs:
Zone,Average,EMPD Surface Inside Face Water Vapor Density [kg/m3]
Zone,Average,EMPD Surface Inside Face Humidity Ratio [kgWater/kgDryAir]
Zone,Average,EMPD Surface Inside Face Relative Humidity [%]
Zone,Average,HAMT Surface Temperature Cell N [C]
Zone,Average,HAMT Surface Water Content Cell N [kg/kg]
Zone,Average,HAMT Surface Relative Humidity Cell N [%]
Zone,Average,HAMT Surface Average Water Content Ratio [kg/kg]
Zone,Average,HAMT Surface Inside Face Temperature [C]
Zone,Average,HAMT Surface Inside Face Relative Humidity [%]
Zone,Average,HAMT Surface Inside Face Vapor Pressure [Pa]
Zone,Average,HAMT Surface Outside Face Temperature [C]
Zone,Average,HAMT Surface Outside Face Relative Humidity [%]
Source: https://bigladdersoftware.com/epx/docs/9-4/input-output-reference/group-surface-construction-elements.html
I don't know what you have defined in the model.
The EnergyPlus engine has hundreds of outputs that can be requested and they depend on the model you have defined.I don't remember all of them by heart.
If possible, please provide the dsb or idf file so I can provide more specific guidance.
I don't know what you have defined in the model. The EnergyPlus engine has hundreds of outputs that can be requested and I don't remember all of them by heart. If possible, please provide the dsb or idf file so I can provide more specific guidance.
Zone,Average,EMPD Surface Inside Face Water Vapor Density [kg/m3] Zone,Average,EMPD Surface Inside Face Humidity Ratio [kgWater/kgDryAir] Zone,Average,EMPD Surface Inside Face Relative Humidity [%]
Zone,Average,HAMT Surface Temperature Cell N [C] Zone,Average,HAMT Surface Water Content Cell N [kg/kg] Zone,Average,HAMT Surface Relative Humidity Cell N [%] Zone,Average,HAMT Surface Average Water Content Ratio [kg/kg] Zone,Average,HAMT Surface Inside Face Temperature [C] Zone,Average,HAMT Surface Inside Face Relative Humidity [%] Zone,Average,HAMT Surface Inside Face Vapor Pressure [Pa] Zone,Average,HAMT Surface Outside Face Temperature [C] Zone,Average,HAMT Surface Outside Face Relative Humidity [%] Zone,Average,HAMT Surface Inside Face Relative Humidity [%]
