An issue was identified when transitioning your file from 9.1 to 9.2 related to Table:TwoIndependentVariables to Table:Lookup. The issue is completely due to the EnergyPlus "transition" programs that are called from IDFVersionUpdater. I posted a GIthub issue about this here:
https://github.com/NREL/EnergyPlus/issues/10568
If you come across a similar failure shown when transitioning from 9.2 to 9.3 it may be caused by an incomplete transition from 9.1 to 9.2.
