@Kostas774
I suggest changing the EnergyPlus version from 8.9.0.001 to 9.4.0.002 in the Program Options. image description
This should change the user interface in DesignBuilder and then you should see the Specify Year checkbox and Start Year field where you will place the value, for example, 2002.
