You can use the "Table View" tab and the export functions in jEPlus+EA's GUI to get all the solutions.
In your .rvi file, the second line should read "eplusout.csv". jEPlus only read this file and rename it to "SimResultsADRIA.csv" as you have specified. If you look inside the job folders, the eplusout-comfort.csv should still be there, which contains the monthly output.
jEPlus doesn't know how to aggregate monthly data. You will have to write your own script to collect and process them. You can incorporate the script(s) in jEPlus so that they are run as part of the postprocessing.
