If the geometry of the building is relatively simple and you don't mind the exact positions of the windows, you can simplify the model by using the "window" objects with multipliers to replace "FenestrationSurface:Detailed" objects, and then with jEPlus to manipulate the sizes. In your case, it is perhaps best to generate multiple IDF files, extract the relevant parts for the geometries, and then use EP-Macro's "##include" function to combine them into a jEPlus project. Here is some information about using EP-Macro with jEPlus: https://www.jeplus.org/wiki/doku.php?id=docs:jeplus:v21:examples#work_with_ep-macro.
