The design intent for ResultsViewer was that you should be able to set your color scale and color map by either right clicking or selecting then plot properties button and going to the flood plot section. Testing this in 1.8.0 this does not seem to work correctly, I filed this bug if you want to follow the issue. The daylighting plots have a similar control.
