For window AC, use PTAC. For the unit ventilators, I would use PTAC with outdoor air supply. If the unit ventilators have energy recovery device, then you will need to use an air loop and an AHU. You then use schedules to control the OA.
For window AC, use PTAC. For for the unit ventilators, I would use either PTAC with outdoor air supply. If the unit ventilators have energy recovery device, then you will need to use an air loop and an AHU. You you then use schedules to control the OA.
