This is part of the URBANopt output. From my first look there isn't any simple way to remove those outputs. However, since the simulation is going at whatever timestep you've selected, I don't think removing select columns will significantly impact the simulation time.
If you have, as you say, huge UO models, the number of buildings is driving the simulation time to a much larger degree.
I'll continue investigating with developers.
