One is for the system (most likely the highest number since it has additional defrost losses to make up), another is for the total of the zone loads, and a third is for each zone (it appears you only have one zone?). If you had several zones attached to this one system, it would report the load for each one. The outputs for this object can be found here: https://bigladdersoftware.com/epx/docs/23-2/input-output-reference/group-refrigeration.html#refrigerationairchiller
