I don't think it occurs on "any measure". This is a logic error, clearly, as indicated by the Optional not initialized.
In this specific example, it's happening here: https://github.com/NREL/openstudio-extension-gem/blob/7819e99c43810bc518e8d050180fcc8cf7c4ab86/lib/openstudio/extension/core/os_lib_hvac.rb#L750-751
Meaning your Space does not have a ThermalZone attached to it...
And you're hitting it on any measure that does use that os_lib_hvac.rb's createPrimaryAirLoops function.
Unfortunately, the function is wrong (openstudio-extension-gem 0.7.0 and 0.7.1 are affected at least, but that function was removed for the forthcoming release...):
    if space.thermalZone
      thermal_zone = space.thermalZone.get
Should actually be
    if space.thermalZone.is_initialized   # alternative: !space.thermalZone.empty?
Anyways: to work around your issue, please assign a ThermalZone to all of your Spaces. A Space must have a thermal zone in order to be simulated by E+.
