I ran your file and found that it's a bug in EnergyPlus. Indeed the Humidifier:Steam:Gas model will always use "FixedInletWaterTemperature" regardless of the input.
I have proposed a bugfix here. Unfortunately, there is no way for you to workaround the issue with the current EnergyPlus releases.
