I'm running into this issue on a much smaller model: 17 zones. Running OpenStudio 1.7.0+b070178884 on a 13th gen i7. Change one construction in Constructions > Construction Sets (on the default construction set for the model that's applied to all 17 zones as this is a relatively simple model of a single building so there is only one construction set in use) and the computer lags for approximately 1-2 hours. Sometimes more. I tried it on an older Ryzen 1800X and it would lag several hours more on each step, so it's somewhat CPU related but also not specific to this one machine.
Any tips to avoid this?
