To see how any formula was written in any question or answer, including this one, right-click on the expression it and choose "Show Math As > TeX Commands".
For inline formulas, enclose the formula in
$...$. For displayed formulas, use$$...$$. These render differently: $\sum_{i=0}^n i^2 = \frac{(n^2+n)(2n+1)}{6}$ (inline) or $$\sum_{i=0}^n i^2 = \frac{(n^2+n)(2n+1)}{6}\tag{displayed}$$For Greek letters, use
\alpha,\beta, …,\omega: $\alpha, \beta, … \omega$. For uppercase, use\Gamma,\Delta, …,\Omega: $\Gamma, \Delta, …, \Omega$.For superscripts and subscripts, use
^and_. For example,x_i^2: $x_i^2$.Groups. Superscripts, subscripts, and other operations apply only to the next “group”. A “group” is either a single symbol, or any formula surrounded by curly braces
{…}. If you do10^10, you will get a surprise: $10^10$. But10^{10}gives what you probably wanted: $10^{10}$. Use curly braces to delimit a formula to which a superscript or subscript applies:x^5^6is an error;{x^y}^zis ${x^y}^z$, andx^{y^z}is $x^{y^z}$. Observe the difference betweenx_i^2$x_i^2$ andx_{i^2}$x_{i^2}$.Parentheses Ordinary symbols
()[]make parentheses and brackets $(2+3)[4+4]$. Use\{and\}for curly braces ${}$.These do not scale with the formula in between, so if you write
(\frac{\sqrt x}{y^3})the parentheses will be too small: $(\frac{\sqrt x}{y^3})$. Using\left(…\right)will make the sizes adjust automatically to the formula they enclose:\left(\frac{\sqrt x}{y^3}\right)is $\left(\frac{\sqrt x}{y^3}\right)$.\leftand\rightapply to all the following sorts of parentheses:(and)$(x)$,[and]$[x]$,\{and\}$\lbrace x \rbrace$,|$|x|$,\langleand\rangle$\langle x \rangle$,\lceiland\rceil$\lceil x \rceil$, and\lfloorand\rfloor$\lfloor x \rfloor$. There are also invisible parentheses, denoted by.:\left.\frac12\right\rbraceis $\left.\frac12\right\rbrace$.Sums and integrals
\sumand\int; the subscript is the lower limit and the superscript is the upper limit, so for example\sum_1^n$\sum_1^n$. Don't forget{…}if the limits are more than a single symbol. For example,\sum_{i=0}^\infty i^2is $\sum_{i=0}^\infty i^2$. Similarly,\prod$\prod$,\int$\int$,\bigcup$\bigcup$,\bigcap$\bigcap$,\iint$\iint$.Fractions There are two ways to make these.
\frac abapplies to the next two groups, and produces $\frac ab$; for more complicated numerators and denominators use{…}:\frac{a+1}{b+1}is $\frac{a+1}{b+1}$. If the numerator and denominator are complicated, you may prefer\over, which splits up the group that it is in:{a+1\over b+1}is ${a+1\over b+1}$.Fonts
- Use
\mathbbor\Bbbfor "blackboard bold": $\mathbb{CHNQRZ}$. - Use
\mathbffor boldface: $\mathbf{ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ $\mathbf{abcdefghijklmnopqrstuvwxyz}$. - Use
\mathttfor "typewriter" font: $\mathtt{ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ $\mathtt{abcdefghijklmnopqrstuvwxyz}$. - Use
\mathrmfor roman font: $\mathrm{ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ $\mathrm{abcdefghijklmnopqrstuvwxyz}$. - Use
\mathsffor sans-serif font: $\mathsf{ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ $\mathsf{abcdefghijklmnopqrstuvwxyz}$. - Use
\mathcalfor "calligraphic" letters: $\mathcal{ ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ - Use
\mathscrfor script letters: $\mathscr{ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ - Use
\mathfrakfor "Fraktur" (old German style) letters: $\mathfrak{ABCDEFGHIJKLMNOPQRSTUVWXYZ} \mathfrak{abcdefghijklmnopqrstuvwxyz}$.
- Use
Radical signs Use
sqrt, which adjusts to the size of its argument:\sqrt{x^3}$sqrt{x^3}$;\sqrt[3]{\frac xy}$sqrt[3]{\frac xy}$. For complicated expressions, consider using{...}^{1/2}instead.Some special functions such as "lim", "sin", "max", "ln", and so on are normally set in roman font instead of italic font. Use
\lim,\sin, etc. to make these:\sin x$sin x$, notsin x$sin x$. Use subscripts to attach a notation to\lim:\lim_{x\to 0}$$\lim_{x\to 0}$$There are a very large number of special symbols and notations, too many to list here; see this shorter listing, or this exhaustive listing. Some of the most common include:
\lt \gt \le \ge \neq$\lt\, \gt\, \le\, \ge\, \neq$. You can use\notto put a slash through almost anything:\not\lt$\not\lt$ but it often looks bad.\times \div \pm \mp$\times\, \div\, \pm\, \mp$.\cdotis a centered dot: $x\cdot y$\cup \cap \setminus \subset \subseteq \subsetneq \supset \in \notin \emptyset \varnothing$\cup\, \cap\, \setminus\, \subset\, \subseteq \,\subsetneq \,\supset\, \in\, \notin\, \emptyset\, \varnothing${n+1 \choose 2k}or\binom{n+1}{2k}${n+1 \choose 2k}$\to \rightarrow \leftarrow \Rightarrow \Leftarrow \mapsto$\to\, \rightarrow\, \leftarrow\, \Rightarrow\, \Leftarrow\, \mapsto$\land \lor \lnot \forall \exists \top \bot \vdash \vDash$\land\, \lor\, \lnot\, \forall\, \exists\, \top\, \bot\, \vdash\, \vDash$\star \ast \oplus \circ \bullet$\star\, \ast\, \oplus\, \circ\, \bullet$\approx \sim \simeq \cong \equiv \prec$\approx\, \sim \, \simeq\, \cong\, \equiv\, \prec$.\infty \aleph_0$\infty\, \aleph_0$\nabla \partial$\nabla\, \partial$\Im \Re$\Im\, \Re$- For modular equivalence, use
\pmodlike this:a\equiv b\pmod n$a\equiv b\pmod n$. \ldotsis the dots in $a_1, a_2, \ldots ,a_n$\cdotsis the dots in $a_1+a_2+\cdots+a_n$- Some Greek letters have variant forms:
\epsilon \varepsilon$\epsilon\, \varepsilon$,\phi \varphi$\phi\, \varphi$, and others. Script lowercase l is\ell$\ell$.
Detexify lets you draw a symbol on a web page and then lists the $\TeX$ symbols that seem to resemble it. These are not guaranteed to work in MathJax but are a good place to start. To check that a command is supported, note that MathJax.org maintains a list of currently supported $\LaTeX$ commands, and one can also check Dr. Carol JVF Burns's page of $\TeX$ Commands Available in MathJax.
Spaces MathJax usually decides for itself how to space formulas, using a complex set of rules. Putting extra literal spaces into formulas will not change the amount of space MathJax puts in:
a␣banda␣␣␣␣bare both $a b$. To add more space, use\,for a thin space $a\,b$;\;for a wider space $a\;b$.\quadand\qquadare large spaces: $a\quad b$, $a\qquad b$.To set plain text, use
\text{…}: ${x\in s\mid x\text{ is extra large}}$. You can nest$…$inside of\text{…}.Accents and diacritical marks Use
\hatfor a single symbol $\hat x$,\widehatfor a larger formula $\widehat{xy}$. If you make it too wide, it will look silly. Similarly, there are\bar$\bar x$ and\overline$\overline{xyz}$, and\vec$\vec x$ and\overrightarrow$\overrightarrow{xy}$ and\overleftrightarrow$\overleftrightarrow{xy}$. For dots, as in $\frac d{dx}x\dot x = \dot x^2 + x\ddot x$, use\dotand\ddot.Special characters used for MathJax interpreting can be escaped using the
\character:\$$\$$,\{${$,\_$_$, etc.If you want
\itself, you should use\backslash$\backslash$, because\\is for a new line.
(Tutorial ends here.)
It is important that this note be reasonably short and not suffer from too much bloat. To include more topics, please create short addenda and post them as answers instead of inserting them into this post.
\frac abapplies to the next two groups, and produces $\frac ab$; for more complicated numerators and denominators use{…}:\frac{a+1}{b+1}is $\frac{a+1}{b+1}$. If the numerator and denominator are complicated, you may prefer\over, which splits up the group that it is in:{a+1\over b+1}is ${a+1\overb+1}$.Fonts
- Use
- Use
Radical signs Use
\itself, you should use\backslash$\backslash$, because\\is for a new line. b+1}$
\frac abapplies to the next two groups, and produces $\frac ab$; for more complicated numerators and denominators use{…}:\frac{a+1}{b+1}is $\frac{a+1}{b+1}$. If the numerator and denominator are complicated, you may prefer\over, which splits up the group that it is in:{a+1\over b+1}is ${a+1\overb+1}$b+1}$.Fonts
- Use
- Use
Radical signs Use
To see how any formula was written in any question or answer, including this one, right-click on the expression Trying it and choose "Show Math As > TeX Commands".
For inline formulas, enclose the formula in $...$. For displayed formulas, use $$...$$. These render differently: $\sum_{i=0}^n i^2 = \frac{(n^2+n)(2n+1)}{6}$ (inline) or $$\sum_{i=0}^n i^2 = \frac{(n^2+n)(2n+1)}{6}\tag{displayed}$$
For Greek letters, use \alpha, \beta, …, \omega: $\alpha, \beta, … \omega$. For uppercase, use \Gamma, \Delta, …, \Omega: $\Gamma, \Delta, …, \Omega$.
For superscripts and subscripts, use ^ and _. For example, x_i^2: $x_i^2$.
Groups. Superscripts, subscripts, and other operations apply only to the next “group”. A “group” is either a single symbol, or any formula surrounded by curly braces {…}. If you do 10^10, you will get a surprise: $10^10$. But 10^{10} gives what you probably wanted: $10^{10}$. Use curly braces to delimit a formula to which a superscript or subscript applies: x^5^6 is an error; {x^y}^z is ${x^y}^z$, and x^{y^z} is $x^{y^z}$. Observe the difference between x_i^2 $x_i^2$ and x_{i^2} $x_{i^2}$.
Parentheses Ordinary symbols ()[] make parentheses and brackets $(2+3)[4+4]$. Use \{ and \} for curly braces ${}$.out:
These do not scale with the formula in between, so if you write $$q = U.A.\Delta T$$(\frac{\sqrt x}{y^3}) the parentheses will be too small: $(\frac{\sqrt x}{y^3})$. Using \left(…\right) will make the sizes adjust automatically to the formula they enclose: \left(\frac{\sqrt x}{y^3}\right) is $\left(\frac{\sqrt x}{y^3}\right)$.
$$q = Q\times\rho \times c_p \times \Delta T$$\left and\right apply to all the following sorts of parentheses: ( and ) $(x)$, [ and ] $[x]$, \{ and \} $\lbrace x \rbrace$, | $|x|$, \langle and \rangle $\langle x \rangle$, \lceil and \rceil $\lceil x \rceil$, and \lfloor and \rfloor $\lfloor x \rfloor$. There are also invisible parentheses, denoted by .: \left.\frac12\right\rbrace is $\left.\frac12\right\rbrace$.
Sums and integrals $$H = Q\times\rho \times c_p \times HDD \times X$$\sum and \int; the subscript is the lower limit and the superscript is the upper limit, so for example \sum_1^n $\sum_1^n$. Don't forget {…} if the limits are more than a single symbol. For example, \sum_{i=0}^\infty i^2 is $\sum_{i=0}^\infty i^2$. Similarly, \prod $\prod$, \int $\int$, \bigcup $\bigcup$, \bigcap $\bigcap$, \iint $\iint$.
Fractions There are two ways to make these. \frac ab applies to the next two groups, and produces $\frac ab$; for more complicated numerators and denominators use {…}: \frac{a+1}{b+1} is $\frac{a+1}{b+1}$. If the numerator and denominator are complicated, you may prefer \over, which splits up the group that it is in: {a+1\over b+1} is ${a+1\over b+1}$.
Fonts Where:
Use$H$ is the Annual Heating Energy Consumption, $kWh.year^{-1} = kJ.h.s^{-1}.year^{-1}$\mathbbor\Bbbfor "blackboard bold": $\mathbb{CHNQRZ}$.Use$Q$ is the Airflow rate, $m^{3}.s^{-1}$\mathbffor boldface: $\mathbf{ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ $\mathbf{abcdefghijklmnopqrstuvwxyz}$.Use$\rho$ is the air density, $kg.m^{-3}$\mathttfor "typewriter" font: $\mathtt{ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ $\mathtt{abcdefghijklmnopqrstuvwxyz}$.Use$cp$ is the Specifc heat capacity of air, $J.kg^{-1}.K^{-1}$\mathrmfor roman font: $\mathrm{ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ $\mathrm{abcdefghijklmnopqrstuvwxyz}$.Use$HDD$ is the annual Heating Degree Days, which as the name implies, is homogenous to $day.K.year^{-1}$\mathsffor sans-serif font: $\mathsf{ABCDEFGHIJKLMNOPQRSTUVWXYZ}$ $\mathsf{abcdefghijklmnopqrstuvwxyz}$.Use$X$ is what we're looking for\mathcal"calligraphic" letters: $\mathcal{ ABCDEFGHIJKLMNOPQRSTUVWXYZ}$- Use
Radical signs Use sqrt, which adjusts in order to guarantee the size of its argument: \sqrt{x^3} $sqrt{x^3}$; \sqrt[3]{\frac xy} $sqrt[3]{\frac xy}$. For complicated expressions, consider using {...}^{1/2} instead.
Some special functions such as "lim", "sin", "max", "ln", and so on are normally set in roman font instead of italic font. Use \lim, \sin, etc. to make these: \sin x $sin x$, not sin x $sin x$. Use subscripts to attach a notation to \lim: \lim_{x\to 0} $$\lim_{x\to 0}$$
There are a very large number of special symbols and notations, too many to list here; see this shorter listing, or this exhaustive listing. Some physical dimension of the most common include:
\epsilon \varepsilon$\epsilon\, \varepsilon$,\phi \varphi$\phi\, \varphi$, and others. Script lowercase l is\ell$\ell$.above equation
Spaces MathJax usually decides for itself how to space formulas, using a complex set of rules. Putting extra literal spaces into formulas will not change the amount of space MathJax puts in: a␣b and a␣␣␣␣b are both $a b$. To add more space, use \, for a thin space $a\,b$; \; for a wider space $a\;b$. \quad and \qquad are large spaces: $a\quad b$, $a\qquad b$.Dimensional Analysis:
To set plain text, use \text{…}: ${x\in s\mid x\text{ is extra large}}$. You can nest $…$ inside of \text{…}.
Accents and diacritical marks Use \hat for a single symbol $\hat x$, \widehat for a larger formula $\widehat{xy}$. If you make it too wide, it will look silly. Similarly, there are \bar $\bar x$ and \overline $\overline{xyz}$, and \vec $\vec x$ and \overrightarrow $\overrightarrow{xy}$ and \overleftrightarrow $\overleftrightarrow{xy}$. For dots, as in $\frac d{dx}x\dot x $$ \frac{J.h}{1000.s.year} = \dot x^2 + x\ddot x$, use \dot and \ddot.
Special characters used for MathJax interpreting can be escaped using the \ character: \$ $\$$, \{ ${$, \_ $_$, etc. \frac{m^3}{s} \times \frac{kg}{m^{3}} \times \frac{J}{kg.K} \times \frac{day.K}{year} \times [X]$$
If you want $$\Leftrightarrow \itself, you should use \frac{h}{1000} = day.X$$\backslash $\backslash$, because \\ is for a new line.
(Tutorial ends here.)$$ \Leftrightarrow X = \frac{h}{day.1000}$$
It is important that this note be reasonably short and not suffer from too much bloat. To include more topics, please create short addenda and post them as answers instead of inserting them into this post.$$ \Leftrightarrow X = \frac{24}{1000}$$
