You can't perform an ERI calculation, which requires running multiple energy simulations (e.g., Reference Home, Rated Home, etc.), using the OpenStudio Application. Rather, you run the calculation using the OpenStudio CLI.
Please read the Usage Instructions on how to run an ERI calculation. There's also a lot of description on capabilities, inputs, outputs, etc. in the documentation.
