ResStock currently assumes a dwelling unit aspect ratio of 1.8 (or 1/1.8=0.56 for some building types) as defined here in the options_lookup.tsv.
Unit aspect ratio is defined as "The ratio of front/back wall length to left/right wall length for the unit, excluding any protruding garage wall area." (You can find that definition by searching for "aspect ratio" in this README).
