It appears from the warning message that you have set the temperature set point to a humidity ratio instead of a temperature. Check which type of set point manager is used for temperature control.
Update: when using water coil controller control type = Temperature and humidity ratio, the controller may switch to humidity control where the humidity ratio is the active set point. This is normal and the message is being clarified in the E+ engine software.
Controller temperature setpoint = 6.31E-003 [C]
Controller humidity ratio setpoint = 6.31E-003 [kgWater/kgDryAir]
Regarding this type of water coil controller error message, if the water cooling coil outlet air set point temperature is lower than the chilled water temperature then the controller will throw this message.
Update: when using water coil controller control type = Temperature and humidity ratio, the controller may switch to humidity control where the humidity ratio is the active set point. This is normal and the message is being clarified revised in the E+ engine software.
Update: when using water coil controller control type = Temperature and humidity ratio, the controller may switch to humidity control where the humidity ratio is the active set point. This is normal and the message is being revised in the E+ engine software.
