I am looking at the HVAC Sizing summary in the latest version of EnergyPlus and I do see "total" coil capacity. Depending on the type of coil the report may show only sensible so it would be determined by your input file configuration. If you could post a picture of the table in question, and the version of E+ you are using, it would be easier to understand what you see in those tables.
