The capacity of any refrigeration object is normally specified as the "rated" or "nominal" capacity because that capacity is applicable only at the AHRI test / rating conditions. Nonetheless, for your 1kW chiller, it's surprising to see such a big discrepancy. See my earlier comment - a 1kw compressor is very unusual for a compressor intended for use in a refrigerated warehouse (very small)
