The Honeybee plugin for grasshopper has this capability - the simplest way to see what outputs you'll want is I think to just read through the outputs they extract here:
https://www.ladybug.tools/honeybee-energy/docs/honeybee_energy.result.loadbalance.html
Your model probably won't be using all of these, so just work out which ones are relevant to you (e.g. if you aren't using the airflow network you won't need the AFN outputs etc.).
