I actually managed to fix the issue! Even with it being just one folder down from the C drive, the directory length was still too long. I placed the project directory directly on the C drive and that seemed to fix the issue. Then I ran into the issue of E+ in the seed file using version 23.2 instead of version 23.1 which the PAT seemed to use. I fixed this by deleting the energy plus files in the ParametricAnalysisTool-3.7.0 on my C drive and replacing it with the contents of the energy plus folder labeled EnergyPlusV23-2-0 on my C drive. Hope this helps others that run across the same problem.
