The answer is Yes. Why not try? You can model it in a few minutes.
I just added two HeatExchanger:AirToAir:SensibleAndLatent objects before OutdoorAir:Mixer to an ExampleFile 5ZoneWarmest.idf. No coil is added between the HEXs, but you can do so.
5ZoneWarmest_2HEXs.idf (V23-2-0)
BTW, I haven't seen two Enthalpy Wheels system at least in East Asia. Desiccant Wheel (HeatExchanger:Desiccant:BalancedFlow) or Desiccant Wheel + Sensible/Enthalpy Wheel is often used for efficient dehumidification.
The answer is Yes. Why not try? You can model it in a few minutes.minites.
