Update 11-12-23: I think I managed to make this work using an AirLoop system. I sized it on ventilation requirement and SPECIFICALLY made sure that the heating and cooling design capacity are set to 0, thus ensuring no heating or cooling will take place. You can find my solution here https://www.dropbox.com/scl/fi/fe4n3o3ne099fshmn5p0o/HVAC-Definition-Ground-Source-Heat-Pump-with-Underfloor-Heating.paper?rlkey=j70e8uy9pmflcenvhbe7w5irk&dl=0.
Please excuse the mess with the GSHP that is also in there, although you can use that as well if you feel like it ;)
