I think it's possible if you use Coil:Cooling:DX because the component specifies Node Names Condenser Inlet Node Name
(= comperssor discharge), Evaporator Inlet Node Name
and Evaporator Outlet Node Name
. I'm not sure what "evaporator coil temperature" means. Is it the inlet temperature of the coil or the average temperature or the entire coil? Anyway, please use Evaporator Inlet Node Name
and/or Evaporator Outlet Node Name
according to your purpose. You can output System Node Temperature
of these Nodes.
