Assuming the gbxml import preserves Spaces (e.g. surfaces, loads), in the OpenStudio Application (as suggested here):
- first, add new zones in the "Thermal Zones" tab
- (optional) edit them beforehand, e.g. rename, add thermostat schedules, sizing parameters
- switch over to the "Spaces" tab (just above)
- link (drag-and-drop) newly created thermal zones to the right spaces
This can be automated with an SDK-based script if the model holds hundreds of spaces. Hoping I understood your question correctly.
