Let me try to answer with an example in Ruby. I'm pretty sure you can convert to Python syntax.
  air_loop = OpenStudio::Model::addSystemType7(m).to_AirLoopHVAC.get
  heating_coil = air_loop.supplyComponents(OpenStudio::Model::CoilHeatingWater::iddObjectType).first.to_CoilHeatingWater.get
  hot_water_plant = heating_coil.plantLoop.get
  boiler = hot_water_plant.supplyComponents(OpenStudio::Model::BoilerHotWater::iddObjectType).first.to_BoilerHotWater.get
  puts boiler.name
Every HVACComponent in OpenStudio, including water coils have the methods plantLoop and airLoopHVAC that return the specified system.
air_loop = OpenStudio::Model::addSystemType7(m).to_AirLoopHVAC.get heating_coil = air_loop.supplyComponents(OpenStudio::Model::CoilHeatingWater::iddObjectType).first.to_CoilHeatingWater.get hot_water_plant = heating_coil.plantLoop.get boiler = hot_water_plant.supplyComponents(OpenStudio::Model::BoilerHotWater::iddObjectType).first.to_BoilerHotWater.get puts boiler.name
