You should be able to run the tests using the openstudio CLI rather than calling ruby directly. The openstudio CLI has ruby embedded inside it along with many of the gems (in this case, the openstudio-extension gem) that you need.
So try:
C:\openstudio-3.6.1\bin\openstudio.exe change_building_location_test.rb
