This is a regression in the OpenStudio SDK starting at 3.5.1, I've opened an issue at https://github.com/NREL/OpenStudio/issues/4994
In the meantime, you can just grab the content of the OSM if you want. If you paste this in your model (.osm) it should work just fine, or just recreate the material in the OSapp by hand.
$ cat ~/BCL/69decf20-7926-0130-b7f7-0026b9d40ccf/69e055c0-7926-0130-b7f9-0026b9d40ccf/files/Brick_Fired_Clay_4_in_130_lb_ft3.osm
OS:Material,
{3d35de05-e7a6-41e8-9e58-fd0d752e0899}, !- Handle
Brick - Fired Clay - 4 in. - 130 lb/ft3, !- Name
MediumRough, !- Roughness
0.1016, !- Thickness {m}
1.02, !- Conductivity {W/m-K}
2082.40023861482, !- Density {kg/m3}
790; !- Specific Heat {J/kg-K}
In the meantime, you can just grab the content of the OSM if you want. If you paste this in your model (.osm) it should work just fine, or just recreate the material in the OSapp by hand.fine.
OS:Material,
