There are 3 sets of nodes in the chillers. Apparently you can use the heat recovery nodes with an air-cooled chiller to add heat to a HW plant.
Chiller:Electric:EIR,
A5 , \field Chilled Water Inlet Node Name
\type node
\required-field
A6 , \field Chilled Water Outlet Node Name
\type node
\required-field
A7 , \field Condenser Inlet Node Name
\type node
\note Not required if air-cooled or evaporatively-cooled
A8 , \field Condenser Outlet Node Name
A11, \field Heat Recovery Inlet Node Name
A12, \field Heat Recovery Outlet Node Name
The fatal error that happens with this configuration was probably a mistake and may be corrected. This fatal error seems to occur only with Chiller:Electric:EIR and Chiller:Electric:ReformulatedEIR. Heat recovery should work, without a fatal error, for Chiller:Electric. Condenser flow rate must be specified so that heat recovery calculations can be performed.
\type node
\required-field
\type node
\required-field
\type node
The fatal error that happens with this configuration was probably a mistake and may be corrected. This fatal error seems to occur only with Chiller:Electric:EIR and Chiller:Electric:ReformulatedEIR. Heat recovery should work, without a fatal error, for Chiller:Electric. Condenser flow rate must be specified so that heat recovery calculations can be performed.Chiller:Electric.
\type node
\required-field
\type node
\required-field
\type node
The fatal error that happens with this configuration was probably a mistake and may be corrected. This fatal error seems to occur only with Chiller:Electric:EIR and Chiller:Electric:ReformulatedEIR. Heat recovery should work, without a fatal error, for Chiller:Electric.corrected.
\type node
\required-field
\type node
\required-field
\type node
